[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.net.steiner/main.c
|1 clones ( main.c )| 2 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Mar 26 09:38:39 EDT 2007
Hello martinl,
ANALYSIS
vector/v.net.steiner/main.c functions
init_node_costs (Begins at: 51 Ends at: 74)
Complexity: | 4 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 24 | | OK |
metrics are OK
get_node_costs (Begins at: 80 Ends at: 105)
ParamNBR: | 3 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 26 | | OK |
metrics are OK
mst (Begins at: 107 Ends at: 293)
Complexity: | 19 | * | |
ParamNBR: | 9 | *** | MONSTER |
CalledNBR: | 27 | | OK |
LOC: | 187 | * | |
at least 1 values are close to an outlier please consider revising code
main (Begins at: 295 Ends at: 593)
Complexity: | 20 | * | |
CalledNBR: | 120 | *** | MONSTER |
LOC: | 299 | *** | MONSTER |
2 metric are OUT OF RANGE!
cmp (Begins at: 595 Ends at: 607)
Complexity: | 3 | | OK |
LOC: | 13 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
cmp
In vector/v.net.steiner/main.c clones of cmp are:
vector/v.net.salesman/main.c cmp
lib/cdhc/dcmp.c dcmp
Threshold GRASS6 key metrics values at 2007-03-26 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
