[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.edit/merge.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Mar 28 11:32:58 EDT 2007
Hello martinl,
ANALYSIS
vector/v.edit/merge.c functions
do_merge (Begins at: 43 Ends at: 203)
Complexity: | 18 | * | |
ParamNBR: | 1 | | OK |
CalledNBR: | 47 | * | |
LOC: | 161 | * | |
metrics are OK
merge_lines (Begins at: 205 Ends at: 286)
Complexity: | 9 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 15 | | OK |
LOC: | 82 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-28 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
