[GRASS-QA] GRASS QA: markus |
./grass6/vector/lidar/v.surf.bspline/main.c |no clones | 3
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Mar 30 15:24:28 EDT 2007
Hello markus,
ANALYSIS
vector/lidar/v.surf.bspline/main.c functions
main (Begins at: 38 Ends at: 621)
Complexity: | 62 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 236 | *** | MONSTER |
LOC: | 584 | *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-30 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
