[GRASS-QA] GRASS QA: markus | ./grass6/raster/wildfire/r.spread/spread.c |no clones | 0 monsters | 0 warnings
Sat Mar 31 14:17:51 EDT 2007
Hello markus,
ANALYSIS
raster/wildfire/r.spread/spread.c functions
spread (Begins at: 60 Ends at: 144)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      18 |       |      OK |
LOC:          |      85 |       |      OK |
metrics are OK
cumulative (Begins at: 151 Ends at: 207)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      10 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
update (Begins at: 214 Ends at: 240)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       6 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-31 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
