[GRASS-QA] GRASS QA: hamish | ./grass6/ps/ps.map/do_labels.c |no
clones | 2 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed May 2 03:17:05 EDT 2007
Hello hamish,
ANALYSIS
ps/ps.map/do_labels.c functions
do_labels (Begins at: 25 Ends at: 80)
Complexity: | 7 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 17 | | OK |
LOC: | 56 | | OK |
metrics are OK
do_label (Begins at: 83 Ends at: 361)
Complexity: | 52 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 59 | * | |
LOC: | 279 | *** | MONSTER |
2 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-02 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
