[GRASS-QA] GRASS QA: hamish | ./grass6/lib/symbol/stroke.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed May 2 03:16:53 EDT 2007
Hello hamish,
ANALYSIS
lib/symbol/stroke.c functions
add_coor (Begins at: 24 Ends at: 35)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 12 | | OK |
metrics are OK
stroke_chain (Begins at: 43 Ends at: 134)
Complexity: | 20 | * | |
ParamNBR: | 4 | | OK |
CalledNBR: | 15 | | OK |
LOC: | 92 | | OK |
metrics are OK
S_stroke (Begins at: 142 Ends at: 168)
Complexity: | 4 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 27 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-02 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
