[GRASS-QA] GRASS QA: hamish | ./grass6/display/d.vect/plot1.c |no
clones | 3 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed May 2 06:14:31 EDT 2007
Hello hamish,
ANALYSIS
display/d.vect/plot1.c functions
local_plot_poly (Begins at: 48 Ends at: 71)
Complexity: | 3 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 24 | | OK |
metrics are OK
plot_polyline (Begins at: 76 Ends at: 100)
Complexity: | 8 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 25 | | OK |
metrics are OK
plot_polygon (Begins at: 105 Ends at: 128)
CalledNBR: | 6 | | OK |
LOC: | 24 | | OK |
metrics are OK
plot1 (Begins at: 133 Ends at: 487)
Complexity: | 55 | *** | MONSTER |
ParamNBR: | 16 | *** | MONSTER |
CalledNBR: | 84 | ** | Warning |
LOC: | 355 | *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-02 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
