[GRASS-QA] GRASS QA: soeren | ./grass6/lib/gpde/N_les.c |no clones
| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed May 2 13:43:18 EDT 2007
Hello soeren,
ANALYSIS
lib/gpde/N_les.c functions
N_alloc_spvector (Begins at: 32 Ends at: 71)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 40 | | OK |
metrics are OK
N_alloc_les (Begins at: 73 Ends at: 129)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 57 | | OK |
metrics are OK
N_add_spvector_to_les (Begins at: 131 Ends at: 181)
Complexity: | 4 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 51 | | OK |
metrics are OK
N_print_les (Begins at: 183 Ends at: 225)
CalledNBR: | 5 | | OK |
LOC: | 43 | | OK |
metrics are OK
N_free_spvector (Begins at: 227 Ends at: 252)
CalledNBR: | 3 | | OK |
LOC: | 26 | | OK |
metrics are OK
N_free_les (Begins at: 254 Ends at: 295)
Complexity: | 10 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 42 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-02 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
