[GRASS-QA] GRASS QA: soeren | ./grass6/lib/gpde/N_solvers.c |2
clones ( N_solvers.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed May 2 13:43:18 EDT 2007
Hello soeren,
ANALYSIS
lib/gpde/N_solvers.c functions
N_solver_gauss (Begins at: 38 Ends at: 65)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 28 | | OK |
metrics are OK
N_solver_lu (Begins at: 67 Ends at: 126)
CalledNBR: | 12 | | OK |
LOC: | 60 | | OK |
metrics are OK
gauss_elimination (Begins at: 128 Ends at: 156)
Complexity: | 1 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 29 | | OK |
metrics are OK
lu_decomposition (Begins at: 158 Ends at: 192)
ParamNBR: | 2 | | OK |
LOC: | 35 | | OK |
metrics are OK
backward_solving (Begins at: 194 Ends at: 222)
ParamNBR: | 4 | | OK |
LOC: | 29 | | OK |
metrics are OK
forward_solving (Begins at: 224 Ends at: 238)
LOC: | 15 | | OK |
metrics are OK
thomalg (Begins at: 244 Ends at: 286)
Complexity: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 43 | | OK |
metrics are OK
vectmem (Begins at: 288 Ends at: 294)
CalledNBR: | 1 | | OK |
LOC: | 7 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
gauss_seidel jacobi
In lib/gpde/N_solvers.c clones of gauss_seidel are:
lib/gpde/N_solvers.c jacobi
In lib/gpde/N_solvers.c clones of jacobi are:
lib/gpde/N_solvers.c gauss_seidel
Threshold GRASS6 key metrics values at 2007-05-02 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
