[GRASS-QA] GRASS QA: hamish | ./grass6/display/d.vect/plot1.c |no clones | 3 monsters | 0 warnings
Wed May 2 22:36:10 EDT 2007
Hello hamish,
ANALYSIS
display/d.vect/plot1.c functions
local_plot_poly (Begins at: 48 Ends at: 71)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
plot_polyline (Begins at: 76 Ends at: 100)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
plot_polygon (Begins at: 105 Ends at: 128)
CalledNBR:    |       6 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
plot1 (Begins at: 133 Ends at: 483)
Complexity:   |      54 |   *** | MONSTER |
ParamNBR:     |      16 |   *** | MONSTER |
CalledNBR:    |      86 |   *** | MONSTER |
LOC:          |     351 |   *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-02 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
