[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.net.path/path.c |no
clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu May 3 06:36:43 EDT 2007
Hello markus,
ANALYSIS
vector/v.net.path/path.c functions
path (Begins at: 25 Ends at: 281)
Complexity: | 28 | ** | Warning |
ParamNBR: | 5 | * | |
CalledNBR: | 106 | *** | MONSTER |
LOC: | 257 | ** | Warning |
1 metric are OUT OF RANGE!
cmp (Begins at: 283 Ends at: 291)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-03 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
