[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.edit/main.c |no
clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu May 3 09:28:42 EDT 2007
Hello martinl,
ANALYSIS
vector/v.edit/main.c functions
main (Begins at: 22 Ends at: 227)
Complexity: | 38 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 61 | ** | Warning |
LOC: | 206 | ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-03 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
