[GRASS-QA] GRASS QA: glynn | ./grass6/imagery/i.class/draw_cell.c
	|no clones | 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Sat May  5 05:30:05 EDT 2007
Hello glynn,
ANALYSIS
imagery/i.class/draw_cell.c functions
draw_cell (Begins at: 8 Ends at: 68)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      22 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-05 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
