[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.rast/display.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun May 6 17:16:40 EDT 2007
Hello glynn,
ANALYSIS
display/d.rast/display.c functions
display (Begins at: 11 Ends at: 65)
Complexity: | 5 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 15 | | OK |
LOC: | 55 | | OK |
at least 1 values are close to an outlier please consider revising code
cell_draw (Begins at: 67 Ends at: 117)
Complexity: | 3 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 20 | | OK |
LOC: | 51 | | OK |
metrics are OK
mask_raster_array (Begins at: 119 Ends at: 128)
ParamNBR: | 4 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 10 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-06 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
