[GRASS-QA] GRASS QA: glynn | ./grass6/lib/display/raster.c |no clones | 1 monsters | 0 warnings
Sun May 6 17:16:40 EDT 2007
Hello glynn,
ANALYSIS
lib/display/raster.c functions
D_draw_raster (Begins at: 38 Ends at: 45)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
D_draw_d_raster (Begins at: 47 Ends at: 53)
ParamNBR:     |       3 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
D_draw_f_raster (Begins at: 55 Ends at: 61)
LOC:          |       7 |       |      OK |
metrics are OK
D_draw_c_raster (Begins at: 63 Ends at: 86)
LOC:          |      24 |       |      OK |
metrics are OK
D_draw_cell (Begins at: 88 Ends at: 94)
LOC:          |       7 |       |      OK |
metrics are OK
draw_cell (Begins at: 96 Ends at: 146)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      51 |       |      OK |
metrics are OK
D_cell_draw_setup (Begins at: 148 Ends at: 164)
CalledNBR:    |       7 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
D_draw_raster_RGB (Begins at: 166 Ends at: 213)
ParamNBR:     |      10 |   *** | MONSTER |
CalledNBR:    |      17 |       |      OK |
LOC:          |      48 |       |      OK |
1 metric are OUT OF RANGE!
D_cell_draw_end (Begins at: 215 Ends at: 218)
ParamNBR:     |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-06 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
