[GRASS-QA] GRASS QA: glynn | ./grass6/lib/psdriver/Graph_set.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon May 7 11:41:51 EDT 2007
Hello glynn,
ANALYSIS
lib/psdriver/Graph_set.c functions
write_prolog (Begins at: 45 Ends at: 67)
Complexity: | 4 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 23 | | OK |
metrics are OK
in2pt (Begins at: 69 Ends at: 72)
Complexity: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
set_paper (Begins at: 74 Ends at: 98)
CalledNBR: | 11 | | OK |
LOC: | 25 | | OK |
metrics are OK
PS_Graph_set (Begins at: 100 Ends at: 158)
ParamNBR: | 2 | | OK |
CalledNBR: | 18 | | OK |
LOC: | 59 | | OK |
metrics are OK
output (Begins at: 160 Ends at: 167)
CalledNBR: | 3 | | OK |
LOC: | 8 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-07 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
