[GRASS-QA] GRASS QA: paul | ./grass6/lib/driver/Font.c |no clones | 0 monsters | 0 warnings
Mon May 7 20:29:58 EDT 2007
Hello paul,
ANALYSIS
lib/driver/Font.c functions
stroke_set (Begins at: 13 Ends at: 17)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
freetype_set (Begins at: 19 Ends at: 23)
LOC:          |       5 |       |      OK |
metrics are OK
COM_Font_get (Begins at: 25 Ends at: 50)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
COM_Font_init_charset (Begins at: 52 Ends at: 55)
Complexity:   |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
font_is_freetype (Begins at: 57 Ends at: 60)
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-07 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
