[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.info/main.c |no clones | 3 monsters | 0 warnings
Tue May 8 03:04:20 EDT 2007
Hello hamish,
ANALYSIS
raster/r.info/main.c functions
main (Begins at: 35 Ends at: 440)
Complexity:   |      57 |   *** | MONSTER |
CalledNBR:    |     198 |   *** | MONSTER |
LOC:          |     406 |   *** | MONSTER |
3 metric are OUT OF RANGE!
format_double (Begins at: 443 Ends at: 449)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-08 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
