[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.support/front/front.c |no clones | 1 monsters | 0 warnings
Wed May 9 08:43:32 EDT 2007
Hello markus,
ANALYSIS
raster/r.support/front/front.c functions
main (Begins at: 33 Ends at: 299)
Complexity:   |      26 |    ** | Warning |
CalledNBR:    |     138 |   *** | MONSTER |
LOC:          |     267 |    ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-09 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
