[GRASS-QA] GRASS QA: glynn |
./grass6/lib/db/dbmi_client/c_list_tabs.c |1 clones (
c_list_tabs.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed May 9 13:45:14 EDT 2007
Hello glynn,
ANALYSIS
lib/db/dbmi_client/c_list_tabs.c functions
cmp_dbstr (Begins at: 6 Ends at: 19)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 14 | | OK |
metrics are OK
db_list_tables (Begins at: 22 Ends at: 45)
Complexity: | 6 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 24 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
db_list_tables
In lib/db/dbmi_client/c_list_tabs.c clones of db_list_tables are:
lib/db/dbmi_client/c_list_idx.c db_list_indexes
Threshold GRASS6 key metrics values at 2007-05-09 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
