[GRASS-QA] GRASS QA: glynn |
./grass6/display/drivers/XDRIVER/Polydots.c |2 clones (
Polydots.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed May 9 17:12:11 EDT 2007
Hello glynn,
ANALYSIS
display/drivers/XDRIVER/Polydots.c functions
XD_Polydots_abs (Begins at: 6 Ends at: 24)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 19 | | OK |
metrics are OK
XD_Polydots_rel (Begins at: 26 Ends at: 49)
LOC: | 24 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
XD_Polydots_abs XD_Polydots_rel
In display/drivers/XDRIVER/Polydots.c clones of XD_Polydots_abs are:
display/drivers/XDRIVER/Polyline.c XD_Polyline_abs
In display/drivers/XDRIVER/Polydots.c clones of XD_Polydots_rel are:
FILE_PATH FNAME
display/drivers/XDRIVER/Polyline.c XD_Polyline_rel
Threshold GRASS6 key metrics values at 2007-05-09 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
