[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/rem_proto.c |no clones | 0 monsters | 0 warnings
Thu May 10 14:47:46 EDT 2007
Hello glynn,
ANALYSIS
lib/raster/rem_proto.c functions
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-10 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
