[GRASS-QA] GRASS QA: hamish | ./grass6/display/d.rast.num/number.c |no clones | 1 monsters | 0 warnings
Mon May 14 03:08:11 EDT 2007
Hello hamish,
ANALYSIS
display/d.rast.num/number.c functions
main (Begins at: 53 Ends at: 315)
Complexity:   |      21 |     * |         |
CalledNBR:    |      93 |   *** | MONSTER |
LOC:          |     263 |    ** | Warning |
1 metric are OUT OF RANGE!
draw_number (Begins at: 319 Ends at: 367)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-14 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
