[GRASS-QA] GRASS QA: martinl |
./grass6/vector/v.build.polylines/walk.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon May 14 04:35:37 EDT 2007
Hello martinl,
ANALYSIS
vector/v.build.polylines/walk.c functions
find_next_line (Begins at: 11 Ends at: 31)
Complexity: | 4 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 21 | | OK |
metrics are OK
walk_back (Begins at: 38 Ends at: 77)
Complexity: | 5 | | OK |
ParamNBR: | 2 | | OK |
LOC: | 40 | | OK |
metrics are OK
walk_forward_and_pick_up_coords (Begins at: 81 Ends at: 147)
Complexity: | 6 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 17 | | OK |
LOC: | 67 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
