[GRASS-QA] GRASS QA: markus | ./grass6/lib/vector/Vlib/snap.c |no clones | 1 monsters | 0 warnings
Mon May 14 11:17:50 EDT 2007
Hello markus,
ANALYSIS
lib/vector/Vlib/snap.c functions
add_item (Begins at: 57 Ends at: 94)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
Vect_snap_lines_list (Begins at: 97 Ends at: 400)
Complexity:   |      27 |    ** | Warning |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      74 |    ** | Warning |
LOC:          |     304 |   *** | MONSTER |
1 metric are OUT OF RANGE!
sort_new (Begins at: 403 Ends at: 425)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
Vect_snap_lines (Begins at: 428 Ends at: 464)
CalledNBR:    |      12 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-14 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
