[GRASS-QA] GRASS QA: scott | ./grass6/lib/edit/edit_cellhd.c |no
clones | 3 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon May 14 15:46:49 EDT 2007
Hello scott,
ANALYSIS
lib/edit/edit_cellhd.c functions
format_value (Begins at: 129 Ends at: 141)
Complexity: | 2 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 1 | | OK |
LOC: | 13 | | OK |
at least 1 values are close to an outlier please consider revising code
format_northing (Begins at: 144 Ends at: 147)
Complexity: | 1 | | OK |
ParamNBR: | 3 | | OK |
LOC: | 4 | | OK |
metrics are OK
format_easting (Begins at: 150 Ends at: 153)
LOC: | 4 | | OK |
metrics are OK
format_resolution (Begins at: 156 Ends at: 159)
LOC: | 4 | | OK |
metrics are OK
E_edit_cellhd (Begins at: 162 Ends at: 552)
Complexity: | 59 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 119 | *** | MONSTER |
LOC: | 391 | *** | MONSTER |
3 metric are OUT OF RANGE!
hitreturn (Begins at: 555 Ends at: 568)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 14 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
