[GRASS-QA] GRASS QA: markus | ./grass6/lib/gis/null_val.c |4 clones ( null_val.c )| 0 monsters | 0 warnings
Mon May 14 21:47:16 EDT 2007
Hello markus,
ANALYSIS
lib/gis/null_val.c functions
EmbedGivenNulls (Begins at: 63 Ends at: 109)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      47 |       |      OK |
metrics are OK
InitError (Begins at: 111 Ends at: 132)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
G__init_null_patterns (Begins at: 134 Ends at: 189)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      56 |       |      OK |
metrics are OK
G__set_null_value (Begins at: 191 Ends at: 212)
CalledNBR:    |       3 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
G_set_null_value (Begins at: 214 Ends at: 243)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       3 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
G_set_c_null_value (Begins at: 245 Ends at: 274)
CalledNBR:    |       1 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
G_set_f_null_value (Begins at: 276 Ends at: 305)
LOC:          |      30 |       |      OK |
metrics are OK
G_set_d_null_value (Begins at: 307 Ends at: 352)
LOC:          |      46 |       |      OK |
metrics are OK
G_is_null_value (Begins at: 354 Ends at: 390)
CalledNBR:    |       4 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
G_is_c_null_value (Begins at: 392 Ends at: 444)
Complexity:   |       3 |       |      OK |
LOC:          |      53 |       |      OK |
metrics are OK
G_is_f_null_value (Begins at: 446 Ends at: 487)
LOC:          |      42 |       |      OK |
metrics are OK
G_is_d_null_value (Begins at: 489 Ends at: 540)
LOC:          |      52 |       |      OK |
metrics are OK
G_insert_null_values (Begins at: 542 Ends at: 569)
LOC:          |      28 |       |      OK |
metrics are OK
G_insert_c_null_values (Begins at: 571 Ends at: 597)
LOC:          |      27 |       |      OK |
metrics are OK
G_insert_f_null_values (Begins at: 599 Ends at: 625)
LOC:          |      27 |       |      OK |
metrics are OK
G_insert_d_null_values (Begins at: 627 Ends at: 639)
LOC:          |      13 |       |      OK |
metrics are OK
G__check_null_bit (Begins at: 641 Ends at: 674)
LOC:          |      34 |       |      OK |
metrics are OK
G__set_flags_from_01_random (Begins at: 676 Ends at: 727)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       5 |     * |         |
LOC:          |      52 |       |      OK |
metrics are OK
G__convert_01_flags (Begins at: 729 Ends at: 769)
LOC:          |      41 |       |      OK |
metrics are OK
G__convert_flags_01 (Begins at: 771 Ends at: 807)
LOC:          |      37 |       |      OK |
metrics are OK
G__init_null_bits (Begins at: 809 Ends at: 834)
LOC:          |      26 |       |      OK |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
  G_set_f_null_value  G_set_c_null_value  G_insert_f_null_values  G_insert_c_null_values
In lib/gis/null_val.c clones of  G_insert_f_null_values are:
	lib/gis/null_val.c  G_insert_c_null_values
In lib/gis/null_val.c clones of  G_set_f_null_value are:
	lib/gis/null_val.c  G_set_c_null_value
In lib/gis/null_val.c clones of  G_insert_c_null_values are:
	lib/gis/null_val.c  G_insert_f_null_values
In lib/gis/null_val.c clones of  G_set_c_null_value are:
	lib/gis/null_val.c  G_set_f_null_value
Threshold GRASS6 key metrics values at 2007-05-14 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
