[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.edit/args.c |no clones | 0 monsters | 3 warnings
Tue May 15 13:46:54 EDT 2007
Hello martinl,
ANALYSIS
vector/v.edit/args.c functions
parser (Begins at: 3 Ends at: 265)
Complexity:   |      28 |    ** | Warning |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      67 |    ** | Warning |
LOC:          |     263 |    ** | Warning |
at least 3 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
