[GRASS-QA] GRASS QA: hamish | ./grass6/display/d.his/main.c |no clones | 1 monsters | 0 warnings
Wed May 16 03:12:36 EDT 2007
Hello hamish,
ANALYSIS
display/d.his/main.c functions
main (Begins at: 31 Ends at: 286)
Complexity:   |      27 |    ** | Warning |
CalledNBR:    |      95 |   *** | MONSTER |
LOC:          |     256 |    ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
