[GRASS-QA] GRASS QA: glynn | ./grass6/lib/psdriver/Graph_set.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed May 16 14:02:32 EDT 2007
Hello glynn,
ANALYSIS
lib/psdriver/Graph_set.c functions
write_prolog (Begins at: 53 Ends at: 96)
Complexity: | 5 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 24 | | OK |
LOC: | 44 | | OK |
metrics are OK
in2pt (Begins at: 98 Ends at: 101)
Complexity: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
swap (Begins at: 103 Ends at: 108)
ParamNBR: | 2 | | OK |
LOC: | 6 | | OK |
metrics are OK
get_paper (Begins at: 110 Ends at: 154)
Complexity: | 6 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 45 | | OK |
metrics are OK
PS_Graph_set (Begins at: 156 Ends at: 210)
Complexity: | 4 | | OK |
LOC: | 55 | | OK |
metrics are OK
output (Begins at: 212 Ends at: 219)
CalledNBR: | 3 | | OK |
LOC: | 8 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
