[GRASS-QA] GRASS QA: markus |
./grass6/imagery/i.ortho.photo/photo.2image/curses.c |7
clones ( curses.c signature.c curses.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed May 16 17:04:21 EDT 2007
Hello markus,
ANALYSIS
imagery/i.ortho.photo/photo.2image/curses.c functions
make_window (Begins at: 11 Ends at: 31)
Complexity: | 2 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 21 | | OK |
metrics are OK
Begin_curses (Begins at: 33 Ends at: 54)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 22 | | OK |
metrics are OK
End_curses (Begins at: 56 Ends at: 65)
CalledNBR: | 3 | | OK |
LOC: | 10 | | OK |
metrics are OK
Suspend_curses (Begins at: 67 Ends at: 75)
CalledNBR: | 4 | | OK |
LOC: | 9 | | OK |
metrics are OK
Resume_curses (Begins at: 77 Ends at: 85)
LOC: | 9 | | OK |
metrics are OK
Curses_allow_interrupts (Begins at: 87 Ends at: 96)
LOC: | 10 | | OK |
metrics are OK
Curses_clear_window (Begins at: 98 Ends at: 113)
Complexity: | 3 | | OK |
LOC: | 16 | | OK |
metrics are OK
Curses_outline_window (Begins at: 115 Ends at: 145)
Complexity: | 4 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 31 | | OK |
metrics are OK
Curses_write_window (Begins at: 147 Ends at: 174)
Complexity: | 6 | | OK |
LOC: | 28 | | OK |
metrics are OK
Curses_replot_screen (Begins at: 176 Ends at: 185)
LOC: | 10 | | OK |
metrics are OK
Curses_prompt_gets (Begins at: 187 Ends at: 235)
ParamNBR: | 2 | | OK |
LOC: | 49 | | OK |
metrics are OK
Beep (Begins at: 237 Ends at: 243)
CalledNBR: | 2 | | OK |
LOC: | 7 | | OK |
metrics are OK
Curses_getch (Begins at: 245 Ends at: 277)
Complexity: | 7 | | OK |
LOC: | 33 | | OK |
metrics are OK
Clone analysis:
This file has 7 potentially cloned functions:
Begin_curses Curses_clear_window Curses_getch Curses_write_window make_window Curses_prompt_gets Curses_outline_window
In imagery/i.ortho.photo/photo.2image/curses.c clones of Curses_outline_window are:
imagery/i.vpoints/curses.c Curses_outline_window
imagery/i.points/curses.c Curses_outline_window
In imagery/i.ortho.photo/photo.2image/curses.c clones of Curses_prompt_gets are:
imagery/i.points/curses.c Curses_prompt_gets
In imagery/i.ortho.photo/photo.2image/curses.c clones of make_window are:
imagery/i.vpoints/curses.c make_window
imagery/i.points/curses.c make_window
In imagery/i.ortho.photo/photo.2image/curses.c clones of Curses_getch are:
imagery/i.vpoints/curses.c Curses_getch
imagery/i.points/curses.c Curses_getch
imagery/i.ortho.photo/photo.2target/curses.c Curses_getch
In imagery/i.ortho.photo/photo.2image/curses.c clones of Curses_write_window are:
imagery/i.vpoints/curses.c Curses_write_window
imagery/i.points/curses.c Curses_write_window
In imagery/i.ortho.photo/photo.2image/curses.c clones of Curses_clear_window are:
imagery/i.vpoints/curses.c Curses_clear_window
imagery/i.points/curses.c Curses_clear_window
In imagery/i.ortho.photo/photo.2image/curses.c clones of Begin_curses are:
imagery/i.vpoints/curses.c Begin_curses
imagery/i.ortho.photo/photo.2target/curses.c Begin_curses
Threshold GRASS6 key metrics values at 2007-05-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
