[GRASS-QA] GRASS QA: markus | ./grass6/imagery/i.ortho.photo/photo.2target/digit.c |3 clones ( curses.c signature.c curses.c curses.c digit.c )| 0 monsters | 0 warnings
Wed May 16 17:04:21 EDT 2007
Hello markus,
ANALYSIS
imagery/i.ortho.photo/photo.2target/digit.c functions
setup_digitizer (Begins at: 11 Ends at: 46)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
setup (Begins at: 48 Ends at: 66)
Complexity:   |       2 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
digitizer_point (Begins at: 68 Ends at: 102)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
oops (Begins at: 104 Ends at: 110)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
no (Begins at: 112 Ends at: 116)
CalledNBR:    |       0 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
yes (Begins at: 118 Ends at: 122)
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
This file has 3 potentially cloned functions:
  setup_digitizer  setup  digitizer_point
In imagery/i.ortho.photo/photo.2target/digit.c clones of  digitizer_point are:
	imagery/i.vpoints/digit.c  digitizer_point
	imagery/i.points/digit.c  digitizer_point
In imagery/i.ortho.photo/photo.2target/digit.c clones of  setup are:
	imagery/i.vpoints/digit.c  setup
	imagery/i.points/digit.c  setup
In imagery/i.ortho.photo/photo.2target/digit.c clones of  setup_digitizer are:
	imagery/i.vpoints/digit.c  setup_digitizer
	imagery/i.points/digit.c  setup_digitizer
Threshold GRASS6 key metrics values at 2007-05-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
