[GRASS-QA] GRASS QA: markus | ./grass6/imagery/i.points/curses.c |6 clones ( curses.c signature.c curses.c curses.c digit.c curses.c )| 0 monsters | 0 warnings
Wed May 16 17:04:22 EDT 2007
Hello markus,
ANALYSIS
imagery/i.points/curses.c functions
make_window (Begins at: 11 Ends at: 31)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
Begin_curses (Begins at: 33 Ends at: 55)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
End_curses (Begins at: 57 Ends at: 66)
CalledNBR:    |       3 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
Suspend_curses (Begins at: 68 Ends at: 76)
CalledNBR:    |       4 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Resume_curses (Begins at: 78 Ends at: 86)
LOC:          |       9 |       |      OK |
metrics are OK
Curses_allow_interrupts (Begins at: 88 Ends at: 97)
LOC:          |      10 |       |      OK |
metrics are OK
Curses_clear_window (Begins at: 99 Ends at: 114)
Complexity:   |       3 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
Curses_outline_window (Begins at: 116 Ends at: 146)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
Curses_write_window (Begins at: 148 Ends at: 175)
Complexity:   |       6 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
Curses_replot_screen (Begins at: 179 Ends at: 188)
LOC:          |      10 |       |      OK |
metrics are OK
Curses_prompt_gets (Begins at: 190 Ends at: 238)
LOC:          |      49 |       |      OK |
metrics are OK
Beep (Begins at: 241 Ends at: 247)
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Curses_getch (Begins at: 250 Ends at: 282)
Complexity:   |       7 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
Clone analysis:
This file has 6 potentially cloned functions:
  Curses_clear_window  Curses_getch  Curses_write_window  make_window  Curses_prompt_gets  Curses_outline_window
In imagery/i.points/curses.c clones of  Curses_outline_window are:
	imagery/i.vpoints/curses.c  Curses_outline_window
	imagery/i.ortho.photo/photo.2image/curses.c  Curses_outline_window
In imagery/i.points/curses.c clones of  Curses_prompt_gets are:
	imagery/i.ortho.photo/photo.2image/curses.c  Curses_prompt_gets
In imagery/i.points/curses.c clones of  make_window are:
	imagery/i.vpoints/curses.c  make_window
	imagery/i.ortho.photo/photo.2image/curses.c  make_window
In imagery/i.points/curses.c clones of  Curses_getch are:
	imagery/i.vpoints/curses.c  Curses_getch
	imagery/i.ortho.photo/photo.2target/curses.c  Curses_getch
	imagery/i.ortho.photo/photo.2image/curses.c  Curses_getch
In imagery/i.points/curses.c clones of  Curses_write_window are:
	imagery/i.vpoints/curses.c  Curses_write_window
	imagery/i.ortho.photo/photo.2image/curses.c  Curses_write_window
In imagery/i.points/curses.c clones of  Curses_clear_window are:
	imagery/i.vpoints/curses.c  Curses_clear_window
	imagery/i.ortho.photo/photo.2image/curses.c  Curses_clear_window
Threshold GRASS6 key metrics values at 2007-05-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
