[GRASS-QA] GRASS QA: markus |
./grass6/imagery/i.ortho.photo/menu/run.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed May 16 18:41:27 EDT 2007
Hello markus,
ANALYSIS
imagery/i.ortho.photo/menu/run.c functions
run_etc_imagery (Begins at: 4 Ends at: 18)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 15 | | OK |
metrics are OK
run_system (Begins at: 20 Ends at: 29)
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 10 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
