[GRASS-QA] GRASS QA: hamish | ./grass6/ps/ps.map/r_paper.c |no clones | 0 monsters | 0 warnings
Thu May 17 08:43:28 EDT 2007
Hello hamish,
ANALYSIS
ps/ps.map/r_paper.c functions
read_paper (Begins at: 26 Ends at: 82)
Complexity:   |      15 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      21 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-17 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
