[GRASS-QA] GRASS QA: hamish | ./grass6/display/d.graph/do_graph.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon May 21 05:48:26 EDT 2007
Hello hamish,
ANALYSIS
display/d.graph/do_graph.c functions
set_graph_stuff (Begins at: 25 Ends at: 35)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 11 | | OK |
metrics are OK
set_text_size (Begins at: 37 Ends at: 49)
Complexity: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 13 | | OK |
metrics are OK
do_draw (Begins at: 51 Ends at: 77)
Complexity: | 4 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 27 | | OK |
metrics are OK
do_move (Begins at: 79 Ends at: 97)
LOC: | 19 | | OK |
metrics are OK
do_color (Begins at: 99 Ends at: 129)
Complexity: | 5 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 31 | | OK |
metrics are OK
do_linewidth (Begins at: 131 Ends at: 144)
CalledNBR: | 5 | | OK |
LOC: | 14 | | OK |
metrics are OK
do_poly (Begins at: 147 Ends at: 204)
Complexity: | 9 | | OK |
ParamNBR: | 2 | | OK |
LOC: | 58 | | OK |
metrics are OK
do_size (Begins at: 206 Ends at: 232)
LOC: | 27 | | OK |
metrics are OK
do_rotate (Begins at: 234 Ends at: 245)
LOC: | 12 | | OK |
metrics are OK
do_text (Begins at: 247 Ends at: 258)
Complexity: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 12 | | OK |
metrics are OK
check_alloc (Begins at: 260 Ends at: 293)
CalledNBR: | 4 | | OK |
LOC: | 34 | | OK |
metrics are OK
do_icon (Begins at: 295 Ends at: 345)
CalledNBR: | 18 | | OK |
LOC: | 51 | | OK |
metrics are OK
do_symbol (Begins at: 347 Ends at: 448)
Complexity: | 11 | | OK |
CalledNBR: | 36 | * | |
LOC: | 102 | | OK |
metrics are OK
set_last_color (Begins at: 451 Ends at: 463)
ParamNBR: | 4 | | OK |
LOC: | 13 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-21 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
