[GRASS-QA] GRASS QA: paul | ./grass6/lib/gis/ls.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu May 24 15:48:35 EDT 2007
Hello paul,
ANALYSIS
lib/gis/ls.c functions
cmp_names (Begins at: 29 Ends at: 51)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 23 | | OK |
metrics are OK
G__ls (Begins at: 53 Ends at: 91)
Complexity: | 4 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 39 | | OK |
metrics are OK
G_ls (Begins at: 93 Ends at: 123)
CalledNBR: | 4 | | OK |
LOC: | 31 | | OK |
metrics are OK
G_ls_format (Begins at: 125 Ends at: 181)
Complexity: | 6 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 57 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-24 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
