[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.distance/main.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon May 28 09:17:30 EDT 2007
Hello markus,
ANALYSIS
raster/r.distance/main.c functions
main (Begins at: 25 Ends at: 55)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 31 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-28 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
