[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.rescale.eq/main.c |no clones | 0 monsters | 0 warnings
Mon May 28 12:55:52 EDT 2007
Hello markus,
ANALYSIS
raster/r.rescale.eq/main.c functions
main (Begins at: 25 Ends at: 167)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      45 |     * |         |
LOC:          |     143 |     * |         |
metrics are OK
reclass (Begins at: 169 Ends at: 176)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-28 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
