[GRASS-QA] GRASS QA: hamish | ./grass6/lib/gis/parser.c |no clones | 1 monsters | 9 warnings
Wed May 30 03:19:11 EDT 2007
Hello hamish,
ANALYSIS
lib/gis/parser.c functions
G_disable_interactive (Begins at: 161 Ends at: 182)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
G_define_flag (Begins at: 185 Ends at: 243)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      59 |       |      OK |
metrics are OK
G_define_option (Begins at: 246 Ends at: 328)
LOC:          |      83 |       |      OK |
metrics are OK
G_define_standard_option (Begins at: 331 Ends at: 602)
Complexity:   |      31 |    ** | Warning |
CalledNBR:    |      36 |     * |         |
LOC:          |     272 |   *** | MONSTER |
at least 2 values are close to an outlier please consider revising code
G_define_module (Begins at: 605 Ends at: 657)
CalledNBR:    |       1 |       |      OK |
LOC:          |      53 |       |      OK |
metrics are OK
G_parser (Begins at: 659 Ends at: 925)
Complexity:   |      37 |   *** | MONSTER |
CalledNBR:    |      74 |    ** | Warning |
LOC:          |     267 |    ** | Warning |
at least 3 values are close to an outlier please consider revising code
uses_new_gisprompt (Begins at: 928 Ends at: 978)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      51 |       |      OK |
metrics are OK
G_usage (Begins at: 980 Ends at: 1166)
Complexity:   |      33 |    ** | Warning |
CalledNBR:    |      53 |     * |         |
LOC:          |     187 |     * |         |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 1168 Ends at: 1184)
Complexity:   |       6 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
G_usage_xml (Begins at: 1186 Ends at: 1400)
Complexity:   |      28 |    ** | Warning |
CalledNBR:    |      71 |    ** | Warning |
LOC:          |     215 |    ** | Warning |
G_usage_html (Begins at: 1402 Ends at: 1633)
Complexity:   |      43 |   *** | MONSTER |
CalledNBR:    |      78 |    ** | Warning |
LOC:          |     232 |    ** | Warning |
1 metric are OUT OF RANGE!
G_script (Begins at: 1635 Ends at: 1746)
Complexity:   |      22 |     * |         |
CalledNBR:    |      46 |     * |         |
LOC:          |     112 |       |      OK |
metrics are OK
generate_tcl (Begins at: 1748 Ends at: 1843)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      45 |     * |         |
LOC:          |      96 |       |      OK |
metrics are OK
G_gui (Begins at: 1846 Ends at: 1875)
CalledNBR:    |       8 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
G_tcltk (Begins at: 1878 Ends at: 1893)
LOC:          |      16 |       |      OK |
metrics are OK
show_options (Begins at: 1895 Ends at: 1925)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
show (Begins at: 1927 Ends at: 1940)
CalledNBR:    |       3 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
set_flag (Begins at: 1942 Ends at: 1969)
LOC:          |      28 |       |      OK |
metrics are OK
contains (Begins at: 1974 Ends at: 1983)
LOC:          |      10 |       |      OK |
metrics are OK
set_option (Begins at: 1985 Ends at: 2045)
CalledNBR:    |      13 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
check_opts (Begins at: 2047 Ends at: 2084)
LOC:          |      38 |       |      OK |
metrics are OK
check_an_opt (Begins at: 2086 Ends at: 2128)
ParamNBR:     |       4 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
check_int (Begins at: 2130 Ends at: 2196)
Complexity:   |      13 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
check_double (Begins at: 2198 Ends at: 2238)
LOC:          |      41 |       |      OK |
metrics are OK
check_string (Begins at: 2240 Ends at: 2267)
Complexity:   |       8 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
check_required (Begins at: 2269 Ends at: 2292)
LOC:          |      24 |       |      OK |
metrics are OK
split_opts (Begins at: 2294 Ends at: 2357)
LOC:          |      64 |       |      OK |
metrics are OK
check_multiple_opts (Begins at: 2359 Ends at: 2397)
CalledNBR:    |       5 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
check_overwrite (Begins at: 2400 Ends at: 2456)
Complexity:   |      11 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
interactive (Begins at: 2458 Ends at: 2486)
LOC:          |      29 |       |      OK |
metrics are OK
interactive_flag (Begins at: 2488 Ends at: 2496)
LOC:          |       9 |       |      OK |
metrics are OK
interactive_option (Begins at: 2498 Ends at: 2588)
Complexity:   |      23 |     * |         |
CalledNBR:    |      41 |     * |         |
LOC:          |      91 |       |      OK |
metrics are OK
split_gisprompt (Begins at: 2590 Ends at: 2620)
LOC:          |      31 |       |      OK |
metrics are OK
gis_prompt (Begins at: 2622 Ends at: 2679)
CalledNBR:    |      20 |       |      OK |
LOC:          |      58 |       |      OK |
metrics are OK
G_recreate_command (Begins at: 2681 Ends at: 2783)
CalledNBR:    |      25 |       |      OK |
LOC:          |     103 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-30 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
