[GRASS-QA] GRASS QA: markus | ./grass6/display/d.frame/frame.c |no
	clones | 0 monsters | 1 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Wed May 30 04:46:48 EDT 2007
Hello markus,
ANALYSIS
display/d.frame/frame.c functions
main (Begins at: 37 Ends at: 201)
Complexity:   |      21 |     * |         |
CalledNBR:    |      69 |    ** | Warning |
LOC:          |     165 |     * |         |
at least 1 values are close to an outlier please consider revising code
check_at (Begins at: 205 Ends at: 220)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
list_all (Begins at: 223 Ends at: 240)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-30 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
