[GRASS-QA] GRASS QA: markus | ./grass6/db/base/execute.c |no clones
| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed May 30 04:54:39 EDT 2007
Hello markus,
ANALYSIS
db/base/execute.c functions
main (Begins at: 32 Ends at: 86)
Complexity: | 9 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 26 | | OK |
LOC: | 55 | | OK |
metrics are OK
parse_command_line (Begins at: 88 Ends at: 139)
Complexity: | 4 | | OK |
CalledNBR: | 17 | | OK |
LOC: | 52 | | OK |
metrics are OK
get_stmt (Begins at: 142 Ends at: 168)
CalledNBR: | 8 | | OK |
LOC: | 27 | | OK |
metrics are OK
stmt_is_empty (Begins at: 171 Ends at: 176)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 6 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-30 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
