[GRASS-QA] GRASS QA: markus | ./grass6/display/d.linegraph/linegraph.c |no clones | 2 monsters | 0 warnings
Wed May 30 05:50:11 EDT 2007
Hello markus,
ANALYSIS
display/d.linegraph/linegraph.c functions
main (Begins at: 52 Ends at: 586)
Complexity:   |      34 |    ** | Warning |
CalledNBR:    |     128 |   *** | MONSTER |
LOC:          |     535 |   *** | MONSTER |
2 metric are OUT OF RANGE!
rem (Begins at: 588 Ends at: 592)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
death (Begins at: 596 Ends at: 601)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-30 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
