[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.in.ascii/head.c |1 clones ( head.c )| 0 monsters | 0 warnings
Wed May 30 10:56:24 EDT 2007
Hello martinl,
ANALYSIS
vector/v.in.ascii/head.c functions
read_head (Begins at: 9 Ends at: 58)
Complexity:   |      18 |     * |         |
CalledNBR:    |      33 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  read_head
In vector/v.in.ascii/head.c clones of  read_head are:
	vector/v.edit/a2b.c  read_head
Threshold GRASS6 key metrics values at 2007-05-30 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
