[GRASS-QA] GRASS QA: scott | ./grass6/general/manage/cmd/copy.c |no
	clones | 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Wed May 30 18:48:44 EDT 2007
Hello scott,
ANALYSIS
general/manage/cmd/copy.c functions
main (Begins at: 26 Ends at: 104)
Complexity:   |       9 |       |      OK |
CalledNBR:    |      31 |       |      OK |
LOC:          |      79 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-30 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
