[GRASS-QA] GRASS QA: scott | ./grass6/general/manage/cmd/rename.c |no clones | 0 monsters | 0 warnings
Wed May 30 18:48:44 EDT 2007
Hello scott,
ANALYSIS
general/manage/cmd/rename.c functions
main (Begins at: 27 Ends at: 154)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      57 |     * |         |
LOC:          |     128 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-30 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
