[GRASS-QA] GRASS QA: markus | ./grass6/lib/vask/V_call.c |no clones
| 2 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Nov 2 06:51:11 EDT 2007
Hello markus,
ANALYSIS
lib/vask/V_call.c functions
V_call (Begins at: 147 Ends at: 457)
Complexity: | 64 | *** | MONSTER |
ParamNBR: | 1 | | OK |
CalledNBR: | 87 | *** | MONSTER |
LOC: | 311 | *** | MONSTER |
2 metric are OUT OF RANGE!
V_intrpt_ok (Begins at: 459 Ends at: 477)
Complexity: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 19 | | OK |
metrics are OK
V_intrpt_msg (Begins at: 479 Ends at: 482)
CalledNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
fmt (Begins at: 485 Ends at: 500)
Complexity: | 3 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 16 | | OK |
metrics are OK
centered (Begins at: 503 Ends at: 513)
Complexity: | 2 | | OK |
LOC: | 11 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-11-02 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
