[GRASS-QA] GRASS QA: carlos | ./grass6/lib/gpde/N_arrays_io.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Nov 6 12:53:49 EST 2007
Hello carlos,
ANALYSIS
lib/gpde/N_arrays_io.c functions
N_read_rast_to_array_2d (Begins at: 45 Ends at: 166)
Complexity: | 26 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 42 | * | |
LOC: | 122 | * | |
at least 1 values are close to an outlier please consider revising code
N_write_array_2d_to_rast (Begins at: 168 Ends at: 261)
Complexity: | 16 | * | |
CalledNBR: | 30 | | OK |
LOC: | 94 | | OK |
metrics are OK
N_read_rast3d_to_array_3d (Begins at: 263 Ends at: 390)
Complexity: | 23 | * | |
ParamNBR: | 3 | | OK |
CalledNBR: | 36 | * | |
LOC: | 128 | * | |
metrics are OK
N_write_array_3d_to_rast3d (Begins at: 392 Ends at: 472)
CalledNBR: | 24 | | OK |
LOC: | 81 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-11-06 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
