[GRASS-QA] GRASS QA: hamish | ./grass6/imagery/i.rectify/main.c |no clones | 0 monsters | 0 warnings
Tue Nov 6 20:53:24 EST 2007
Hello hamish,
ANALYSIS
imagery/i.rectify/main.c functions
main (Begins at: 36 Ends at: 185)
Complexity:   |      14 |       |      OK |
CalledNBR:    |      44 |     * |         |
LOC:          |     150 |     * |         |
metrics are OK
err_exit (Begins at: 187 Ends at: 197)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-06 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
