[GRASS-QA] GRASS QA: glynn | ./grass6/lib/datetime/local.c |no clones | 0 monsters | 0 warnings
Sun Nov 11 22:02:09 EST 2007
Hello glynn,
ANALYSIS
lib/datetime/local.c functions
datetime_get_local_timezone (Begins at: 34 Ends at: 84)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      20 |       |      OK |
LOC:          |      51 |       |      OK |
metrics are OK
datetime_get_local_time (Begins at: 87 Ends at: 107)
CalledNBR:    |       9 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-11 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
